mn | The cab post cover gets removed and it's a fairly easy job.
Ease of installation is about the same between the two. However, the all rubber lines will eliminate the quick disconnect (which is a known leak spot) The purpose of them is to eliminate the rust problem in the cab post. But honestly, look how long they have already lasted.
Regardless, make sure you get the roof hose with the low pressure port. That is a far better place for the low pressure switch vs at the pump. | |
