| I use an AL Integra in my combine and have a 40' head for wheat.
I plant 30' and do a lot of plots.
Is there a simple way to change to a 30' header width when I do a side by side plot?
I know I can toggle down the width but a lot of times it reverts back to original header width if you had to stop and lift up so trying to avoid that option and it is hard to go to exactly 30' because it goes down by a percentage.
I can create a 30' and a 40' configuration but I will not be able to see the total acres and/or bushels for the field.
Any suggestions?
