nw NC | I use pieces of 3/8 rebar about 20 inches long. Bend into a shape with a vertical leg 14 inches down, a horizontal leg 2 inches and another vertical leg downward 3 or 4 inches ( looks like a staple with one long leg and one short leg). Put the chain onto the horizontal cross bar and drive the rebar "staple" into the ground with a heavy hammer. Use a pry-bar as a lever under the horizontal cross bar to lift it from the ground when you need to move it. Have not had one moved yet. | |
