Posted 6/30/2020 15:48 (#8345702 - in reply to #8345693) Subject: RE: Newbe AC questions
With todays heat load, those pressures are a little low.
What are the symptoms?
Not cooling well?
With those gauge readings, your compressor is not the issue.
Be cautious as cheap A/C parts like compressors can prove to not be cheap in the long run if you grenade one in a system.
INDY
