Search Forums | Classifieds (119) | Skins | Language
Antennas that work with an Insight and other questions??
pirlbeck
Posted 6/26/2020 13:02 (#8337409 - in reply to #8337125)
Subject: RE: Antennas that work with an Insight and other questions??
West Central Iowa
Thanks for the reply. Besides the Trimble L1 antenna, I also removed a coaxial cable (with 90 degree ends) that was still installed on the combine, but I am thinking this must of been from an earlier yield monitor setup. I am not sure I want to mount that 252 if I could use something more compact and lighter. What would my choices be for a WAAS only antenna/receiver? It seems there have been some links posted here to some cheaper setups in the last 6 months or so.
I am not sure why the CAN bus cable was cut, as I removed the components myself and I did not cut anything, but it may of been cut when someone removed other parts from the combine.
Thanks for the info on repairing the harness, if it is long enough I will give it a try.
Thanks again for your help!
