Arco MN | I haven’t run field IQ on a Hagie but to answer some of your questions you go to configuration or the wrenches/ field IQ/ setup/control setup/ select the correct one and edit. Find rate control then feedback nd there is where you set your minimum flow.
Also go to fieldIQ then diagnostics. And test things to see what flow in gallons per min your minimum flow needs to be.
I am not sure if this will work but when you start a field can you just hold the jump start switch up u til it has a good pattern? Worth a try | |
