| Variable rate turned on? First picture “H” icon is where the on/off is. If variable rate is off the tab will be gone & “variable rate disabled” will display on the rate controller home screen.
Also...noticed your MDV for yellow meter & Milo, we’ve had good results adding tuning rings to the yellow meter with the intent to increase MDV value & make the meter turn faster for the same lbs/acre. Increasing meter revolutions helps with the bunching/sporadic seed dispersal. Better “controlled spill “ if that makes sense.
Edited by greenbine 6/9/2020 23:00
