Idaho | During winter Ag Express software updated our Raven Cruiser II on a Spray Coupe to a 3.5.0 version. Our previous trouble had been the screen not painting green history where we had sprayed. Ag Express has been good as gold to coach me but has gone as far as they are knowledgeable. Raven just puts me on hold. Our current trouble, though not life or death, is the swath the screen paints green is much narrower than the sprayer actually sprays, leaving gaps in the history between passes, most troublesome on irregular shaped edges of fields. The red A-B straight lines are still correctly 80' apart and seems to follow the "vehicle" setting of 960". But the "sections" (5) settings have to be 2 1/2 times larger than 80' to come even close to covering our swath completely with green. It is as if the monitor will never let us enter settings large enough to enlarge the narrower swath enough to not leave 4-5' gaps. The monitor, probably because of our increasing sections values, also counts acres very fast. Luckily the SCS 460 is still metering liquid properly and measuring acres, etc. correctly. I would appreciate any ideas, with Thanks! | |
