Carter Montana | I'm running a Morris three tank cart with Direct Command successfully, and it works fine. I'm considering a four tank cart which would mean another strip till module on the canbus. This part should work fine. I'm weak on clutch modules and whether you could run section control on four tanks and what that would entail. I'm familiar with the relay issue (power sensing within the ccm) but that's about it.
