Posted 5/25/2020 21:25 (#8280155 - in reply to #8279889) Subject: RE: Outback A220 321 compatible?
NE Iowa
Yes it will, just need to make sure the radio settings are all correct. The A321 radio mode is default to 'fast', the 220 can only run on 'slow' mode. You'll need to set the 321 to slow and then everything will work fine. Any other receivers will also need changed or will not make radio link.
