South Central Kansas, Harper County | coryweber1988 - 5/25/2020 20:52
you will need PF90687 harness to connect to the original display to the cornerpost connector in the tractor. You can run the Original display as a secondary monitor (no Mobile processor though) and then run autotrac off the 4600 Commandcenter. This will allow you to run your Air seeder off it. I assuming that is the display you have in the tractor correct? Ive just called it Gen 4 Display, but Im thinking 4600 is correct? I posted this same question in the Machinery talk section and recieved this response "You cannot run a brown box tied into the wiring on the tractor. However, if you have a 2018 or newer tractor it will have a Version 2 server in it (the computing power of the 4600) and it can be updated to current software to run a brown box air seeder. If the tractor is 2014-2017 the server can be upgraded to do this as well." My tractor is a 2015. Any comment on this? I also have a 20/20 display and an IPAD that will not be used, as soon as I unhook from my planter. Would be nice if one of those could be used someway to work with my blockage sensors?
thanks,
Jim
Edited by Jim1_ks 5/26/2020 07:26
