Posted 5/24/2020 09:43 (#8276802 - in reply to #8274232) Subject: RE: how to calibrate soltera electronic meter after the water pump
N.C. Iowa
I just hook the meters to the totes and let the chemical gravity feed into a 5 gallon calibration jug. Then hook it back up to the handler. Has worked fine doing it this way for a couple of years. Lift the totes up in the air or set on trailer and put calibration jug on ground.
