WC Illinois | Have you then deleted internal memory? Had similar issue and needed to go into data, manage data, internal and then delete data. You should check status screen in top left corner to see how much memory is available before deleting and then check available memory afterwards to see if it worked for you. Sometimes I have found if I unplug power from back of 750 for a few minutes and then plug in and restart it will bring back starting screen. Hope this helps and good luck. Make sure you have a copy of field data on usb before deleting the internal memory data. Your saved lines should remain and what you are deleting is the so called yellow painting as you worked the field. | |
