Posted 5/18/2020 09:58 (#8264721 - in reply to #8263962) Subject: RE: Hydraulic downforce PSI issue
Terril, IA
How much oil pressure is your tractor actually putting out through your scv? I had a similar issue this spring and come to find out my tractor was only putting out about 1800 PSI through all of my remotes. Had to have service tech come out and adjust my compensator and relief valve on the tractor and then i had all kinds of pressure. Roughly 2900 PSI and everything worked beautifully after that.
