Posted 5/21/2020 14:15 (#8271711 - in reply to #8262555) Subject: RE: AgLeader Insight, Nav II, Trimble 432 guidance
Most likely a gyro issue on Nav Controller. Have seen a few steering sensor issues cause this but usually it’s a gyro problem in my experience. I would swap nav if you have extra or send to Agexpress and have it checked out. Bad valve solenoid could cause similar problem but seems like they usually will throw a valve fault if coil short out.
