North Central Kansas | In the upper left hand corner there should be a tractor icon. Push on that and a prompt should come up asking if you are moving forward or reverse. It will ask you that when you start also. They updated mine this spring and couldn't figure out what was going on. Need to go back and check for skips now that corn is up. Do not switch while you are planting unless you have the section control set on manual. It will shut off your planter as it thinks the planter has already planted that. Look at your coverage map and you should be able to see if the tractor is ahead or behind. Kind of a stupid deal. | |
