Posted 5/16/2020 12:55 (#8260380 - in reply to #8255884) Subject: RE: 2388 with pro 600, 372 receiver fieldview capable?
Quebec, Canada
Unfortunately no.
I tried setting up 2 different 2388 combines last fall with the CNH adapter that FieldView sells. I was not able to get the yield and moisture data into FieldView using that adapter cable. If you save the yield maps on the data card you can import the maps into FieldView through the data inbox.
