Eastern SD | I doubt you're going to find any that are for that mix, dual 4K via Display port plus an additional DVI channel. You're going to have to adapt to get everything on the same connector style.
Here is one that is for triple display, all HDMI but only 30Hz
https://www.amazon.com/CKL-Keyboard-Switcher-Computers-CKL-923HUA/dp...
Can both devices support 2 4K monitors plus a 3rd at lower resolution?
For how much more expensive the 3 & 4 display KVMs are, I think I'd get a standard dual display 4k 60hz KVM. Then the 3rd monitor I would either leave on one PC or just use it's menu buttons to switch it manually.
I messed with 3 displays for a while switching between 2 PCs. In the end, 2 32" 4K monitors is plenty for my usage.
Edited by AllSand 5/8/2020 21:29
