EKS | Monitor shows sys lo. Book says data lead(green) shorted to ground lead (black) wire.
We have checked some spots on the harness, but have not pulled all the wires out of harness yet. Also checked voltage on wires, one has Tractor voltage, the other is around 9. The 9 is also at the plugin at back of Tractor, unplugged from planter
Should this be 9 or Tractor voltage as well
Harness or monitor?
Any ideas
Thanks | |
