| 2008 MF 8470, the steering is acting up. I believe it must be a valve? The tractors steering will sometimes slip ( ex. Turn hard to right and the steering wheel will keep turning, and you can notice it while you drive) then later randomly when the tractor has been used a while it works exactly the way it should. No slip. This leads me to believe a valve is possibly sticking. Although I do not know where to start looking. Any advice would be much appreciated! TIA | |
