AinIndiana - 4/8/2020 08:47
Helping a friend with a 7060. It has low power steering pressure at idle. I believe it’s a problem with flow divider on gear pump. Another issue is it sometimes slips a little under hard pull. Could this be a clutch adjustment? It is not a powershift. Any help greatly appreciated I am not familiar with these tractors.
I would guess and hope that the torque plate on the flywheel is slipping. Need to split the tractor to change it. Not a bad job. |
