north central Ohio | I have posted this before but thought I’d try again. Deere 328 shuts off randomly will crank but won’t restart till you cycle key then off it goes again. Can go a month without doing it and then do it 3 times in an hour. Other day it shutoff and instead of cycling key left it on and went back unplugged fuel shutoff and plugged it back in and you could hear it reengage. Went back and turned key to start without cycling it off and off it ran. So is it the fuel shut off solenoid or is there a wiring issue? I could see it being either one. Thanks | |
