Posted 4/7/2020 21:57 (#8172639 - in reply to #8172461) Subject: RE: 290 magnum 24 row 1250
Tuscola, IL
Check the connections at the pressure increase and pressure decrease valves on the pneumatic block. Assuming you are running in cab pneumatic down pressure control. If you don’t have in cab pneumatic down pressure control you need to walk through the wizzard and answer no when asked.
