Search Forums | Classifieds (139) | Skins | Language
2001 honda foreman Rubicon trans issue
jcolli140
Posted 4/7/2020 19:18 (#8172177)
Subject: 2001 honda foreman Rubicon trans issue
SC Wisconsin
After starting my 01 Rubicon ill put it in either high or low and it will not come out of first gear. Once it gets to a pretty high rpm the d1/d2/eps light flashes. It doesn't flash a certain code, it will just flashes at a constant rate. Also, if i start it in neutral and put it in reverse, it will bog down aa soon as i push on the throttle, basically just over idle. I bought this last fall for cheap, its got 7500 miles on it so its far from new. I only use it to pull my bedding trailer with a big square of straw around to my hitches so i pretty much stay in low anyways, but would like to have it usable if i decide to take it anywhere this summet or something. Anyone have any ideas?
