Nusbaum Farms LLC Bellfountain, OR | On our PTA325 Steiger, I had the same problem as you. I didn't want to buy the spool, the linkage and go through the hassle of adding 5th valve. So what I did was to add an electric splitter valve from Surplus Center into the 3pt circuit at the rear, up between the cylinders. I figured that I would never need 3pt plus 4 spools, that has proven to be correct. Used one of the spare switches in the dash to power it. Off: it functions as another remote spool. On: 3 point functions. Did that in about '08 and still working great today.
-Orin |
