Madison Co. Virginia | John327, the situation is wildly different from what it ever has been. The choice is not between a cheap ventilator, and an expensive good ventilator. The choice is a cheap ventilator, or no ventilator at all.
If you were in that situation, which would you rather have?
I looked at a couple of the homemade ventilators coming out of the big universities. They're designed to last for a couple of weeks. Not long, but long enough to make a difference. Yes, they'll need more monitoring than a fancy type. But it's still better than none at all. | |
