Slicker than a Yes album. | It's under the boundaries tab. http://manuals.deere.com/omview/OMPFP13250_19/
Select MENU > GREENSTAR 3 PRO > MAPPING > BOUNDARIES tab
The BOUNDARIES tab allows you to record exterior field boundaries as well as interior and headland boundaries. Boundaries calculate acreage and are saved on the USB drive to be unloaded in John Deere's APEX or other compatible desktop software. For best accuracy, exterior boundaries should be driven.
NOTE: Apex is not available in all EAME countries.
NOTE: Client, Farm, and Field can also be created on boundaries tab by selecting NEW from the drop down menus.
PC12925
PC12925-UN-27SEP10
Boundary Types
Available Boundary Types
Exterior — The perimeter of the field.
Passable Interior — The perimeter of an area inside the field which is not farmed, but can be crossed with the vehicle and implement (e.g. waterway).
Impassable Interior — The perimeter of an area inside the field which is not farmed, and cannot be crossed with the vehicle and implement.
Boundary type can be changed to Headland when either an Exterior or Interior boundary has been created. If one of these is created, the boundary type list will change.
PC12926
PC12926-UN-27SEP10
Boundaries with Driven Exterior Headland Boundary
A - Maps Tab
B - Boundaries Tab
C - Flags Tab
D - Client Drop-Down Menu
E - Farm Drop-Down Menu
F - Field Drop-Down Menu
G - Type Drop-Down Menu
H - Headland Group Drop-Down Menu
I - Drive Boundary Check-Box
J - Headland Indicator Check-Box
K - Boundary Offset Input-Box
L - Receiver Offset Toggle
M - Record/Pause
N - Stop Recording
Exterior Headland — The end rows along the sides of the field where the end turns occur.
NOTE: For Exterior Headland, if the Headland Indicator box is checked, the display will count down the distance to the next headland on the Guidance map.
Interior Headland — The end rows or turn rows around an Impassable Interior Boundary.
Headland Group — A combination of one or more related headland boundaries. Different operations may use different headland groups. For instance, there may be a Planter group where the headlands are 36.6 m (120 ft), and a Field Cultivator group where the headlands are 27.4 m (90 ft). Different field operations can require different headlands.
Headland Boundaries can either be driven or offset from the Exterior or Interior Boundary.
NOTE: The defined Headlands need to be large enough for vehicle and implement to turn around without the use of brakes.
NOTE: Headlands are for use with iTEC Pro. Other GreenStar software may view headlands on the Guidance page, but will not utilize them.
NOTE: Section Control functionality is based up on exterior, interior and impassable interior boundaries.
Headlands will show on the Guidance View tab as dashed pink lines to show where the headlands exist in maps and perspective views. Only Exterior Boundaries and Impassable Interior Boundaries can have a Headland Boundary. |
