| Hoping someone can help me. I have a customer with a JD strip till bar and he is adding a Montag Gen 1 fertilizer cart to the back of it. JD bar has the blockage sensors on it that are ISO capable and show up in the Pro700 in his Steiger. We want to put a Mueller ISO node on the Montag cart to control fertilizer rate from the PRO700 with the Task Controller. I am having a hard time figuring out how to tie these systems together. The Mueller ISO node supports the Dickey John Daisy Chain Blockage sensors, but that's not what is on the bar. Also I do not see a fan speed sensor on the Montag cart. Has anyone ran a similar system and if so, how did you do it?
Thanks,
Andrew
Mobile - 740 525 5701 | |
