Near Intersection of I-35 & I-90 Southern Mn. | kswrenchturner05 - 3/31/2020 06:51
From my understanding this will not work. You are forced to go to precision planting V apply. Precision has never really had much of a cheap liquid option. Agleader could accommodate what you are doing.
Yes, I'm using my flow meters on the planter with an Ag Leader system. The starter fertilizer is just monitored since it is delivered by a ground driven pump. Its flow meter is connected to Ag Leader's Application Rate Module. The spray system is the same as a broadcast sprayer setup which monitors and controls the spray. It uses Ag Leader's Liquid Product Control Module. They each operate independently. |
