Terril, IA | not possible as of right now. The way those newer buttons work is all through cases/NH CAN bus. When you press the button on the arm rest it sends a CAN message to activate the steering. Ag leader would have to build a CAN module of some sort in order for it to pick up on these messages and make that button work on an ag leader steering system. Seems simple enough to make a CAN module and I'm sure it could be done but the problem with that is, if Case/NH were to ever update software and change that CAN language, that module would no longer work or be of use. | |
