Osakis, MN | Right or wrong I open my inductor cone valve and let about 15 gallons of water bubble up into it.
Dump three bags of ams in the cone and then open the inductor cone valve again letting it fill full of water.
Start the pump that is after the inductor cone and pump water into the sprayer and crack the inductor cone valve a bit until it slowly starts to flow out with the water stream through the Honda 2" pump. Usually run a few hundred gallons of water before I start inducting the AMS.
Add chemicals and other adjuvants.
Run it till it overflows....... That only happened once. | |
