Posted 3/20/2020 13:14 (#8122537 - in reply to #8121754) Subject: RE: liquid side dress machine setup
NW IN
I use a hydro hydraulic driven pump with a raven regulator and raven flow meter. This is controlled by a raven envisio pro. Hydraulic pump has a bypass teed in after pump back into supply hose about 2 feet before pump. That bypass hose has a gate valve in it to restrict flow to maintain line pressure. All row lines have a check valve and a orfice.
