S'ing in RTK signal John Deere
nicolasag
Posted 3/18/2020 15:56 (#8116391)
Subject: S'ing in RTK signal John Deere
Hello all,
I have 2 JD tractors (6215R, 8370R) in RTK signal who have S'ing movement from the AB line.
Was replaced the wheel angle sensors and re calibrated, also the autotrac hydraulic valve was replaced and re calibrated.
The SF6000 receivers and 2630 display have the latest version of software.
On 6R tractor was increased the ballast with aporx 1000kg on the front axle.
The TCM from Starfire 6000 Receiver was re calibrated many times on flat surface.
The movement from the AB line in RTK signal it's over 10 cm for a short time(1-2 second) after go down to 2-3 cm.
The movement from AB line it's without implement (seeder or tillage).
Do you have some advises in this case? Do you ever had this issue with narrow tires in RTK mode?
Thank you,
