SW NE | I'll identify your valves as they work on both of our slurrystores. They may be Abit different on yours.
In the last pic, the lever at the bottom of the pic with the notches, opens the slide valve inside the Slurrystore and allows the manure to come out to the vertical valve in the same pic. On ours, the manure then goes into the PTO driven pump that either agitates the Slurrystore or fills the manure tanker.
In the second pic, the hand crank above the orange wheel valve rotates the center agitation nozzle, or it's supposed to if it's not rotted off. Open the orange valve and close the horizontal gate valve to center agitate and vice versa to agitate over the top of the Slurrystore. | |
