Near Intersection of I-35 & I-90 Southern Mn. | Note that the line drawing shown is only dealing with seed. If only one variety is being planted at the same time, the Multi-product unlock would not be needed. If it is desirable to have a split planter variety map since two or more varieties are being planted at the same time then the Multi-product unlock would be necessary.
Since the OP has the Multi-product unlock he has the option of setting up his planting configuration as either one variety or more. If he set it up for two he would see two product boxes for the variety names. The map would show two different colors making it easy to see which variety is which. They could be the same or different. If he never does any split planter he may as well set up the configuration for only one variety although it would work fine to just pick the same variety for both sides.
He would also have the ability to work with application products like spray or fertilizer at the same time if he chose to do so. Those products would require modules of their own.
Edited by tedbear 3/13/2020 10:00
