Posted 3/12/2020 08:24 (#8098215 - in reply to #8095638) Subject: RE: 750... switched our 750/ ez-steer from combine to planting tractor...
I'm thinking everything will be fine when you start using it. I feel the ez steer setup works very good. I found that turning down the motor speed to low improved the back and forth jumping of the steering wheel. I'm not sure if this is the shimmy you are referring to but maybe.
