Central Nebraska | I’m a bit confused by that link. Looks like I need to buy antenna’s but no radios?
Some Ubiquiti radios use a built in antenna and others require an additional antenna. I've used a few Rocket M5 radios with sector panel antennas but 99% of the radios I've installed are Nanostation and Nanobeams that are all-in-one. They are also much less expensive! If you have a location on in your setup that can be seen by all your other locations you can get away with simple nanostations and nanobeams. Otherwise you have to use multiple nanostations to create a sector panel or use an Omni antenna on a Rocket or Bullet radio. I've never used an omni antenna as they are not as efficient and more susceptible to interference. |
