Has To Be A Simple Answer (Raven Viper 4 )
dolittle
Posted 7/8/2019 21:45 (#7604189)
Subject: Has To Be A Simple Answer (Raven Viper 4 )
If you get close to trees or sometimes back into a corner it starts beeping at you when you start spraying and is showing you spraying backwards. The only way to shut it up and fix it is push the arrow then a pop up comes up asking if you want to reverse direction and you press yes.
Every time this happens it knows it’s going backwards so why not default to what it knows is right and not make you do this?
