Grays Creek, NC | Is it possible to hook a pro 700 monitor into a non guidance ready magnum 305 to display engine speed, percent power, etc? The plug in for the display is there under the right hand rear panel, but when I plug it in it doesn’t pick up the tractor. I want to use the pro 700 to run a smartrax system so all our equipment will have the same monitor, and I’d like to be able to see tractor info on the screen as well | |
