Columbia Basin, Ephrata, WA | The most direct route will be across highway 26 to Pullman and then down through Lewiston, then take highway 12 on the return trip going to Portland.
You can make the trip as long or short as you have time for. I could show you a little irrigated farming if you have time to swing a little farther north on the way across the state from Seattle. Go to the top of Steptoe, and Palouse Falls would be a good side trip that you could hit either direction if you take the route mentioned above.
Edited by Big Ben 6/23/2019 16:14
