northern edge of north central Missouri | Trying a loner switch pro which was said to be good to see if it will register gallons applied. It does not nor does it increase/decrease using toggle.
Question is...does the loner switch pro need to be of a certain revision and program to work OR can I assume since 2 switch pros do not record gallons applied that the problem is elsewhere?
I have inspected joints and wiring to death on this.
There are a couple of small boxes on the cab wiring harness. Could they cause this??
