IL | I’m running Deere sf1 through the command screen on my 8320r for general tillage. Wanting to use my ag leader system that is RTK from my planter tractor “green” and combine “red” to make fall strips with my bigger tractor. Once done with the fall strips then use Deere again in the spring on SF1 for general tillage. My planter tractor is iso as is the 8320r so is it a simple Deere unlock and then I can go back n forth between systems as needed or once you switch your done? I have a case IH 6130 combine and would entertain switching everything to Deere if I could utilize the valve it has which I can’t find info on. Is this possible?. Also consider switch 8320 to ag leader. TIA | |
