Holland, Indiana (SW IN) | Iceman56 - 6/15/2019 06:40
Finally dry enough to run the sprayer across our PP acres... Weeds are getting out of hand quick with this heat, wanna make sure I get everything killed good before it goes to cover crop.
What spray pressure do you guys like to run with dicamba for the best job. 4830 sprayer with hypro tips spraying 15 gallons of water.
I am spraying 16oz of Dicamba with some RUP, Is there any issue with this? Should I back the Dicamba down and throw some 2-4D in the mix? Ive got a good amount of Marestail and kocia coming
16 OZ of dicamba is cheap IMO don't back down the rate --I doubt if 24D will help any --Hope some RU is 32 OZ or more of a 5.4 product or equivalent --be sure to add Ammonium sulfate and Spreader sticker
All spray cost added together should cost less than $10
As far as spray pressure if nothing around that will hurt 40+ -----15 gal of water is smart will get good coverage
Hope this helps --what a year --Dan |
