Posted 6/16/2019 22:20 (#7563517 - in reply to #7557395) Subject: RE: John Deere 1760 planter wing cylinders settle...just a little
Emporia, ks
the operators manual says if the planter does not raise/lower level, it could be "Check valve leaking in wing lock-up valve" Does anyone know which location that check valve is in? Looks to me like it would be behind the rear hose fitting on the right side of the hydraulic valve as if you were sitting in the tractor. That hose appears to go to the top of the outer right cylinder. Am I thinking right?
