Southern Alberta | Why not just put a telescoping swing on your auger and not fool around with the small drive over. When you change augers it is real easy to upgrade. May need a cement pad for the extending swing auger to run on, they don't like deep truck ruts.
Brands such as Rodono or Tridekon televeyor. Companies such as Brandt, Nuvision, Wheatheart and Westfield all have agreements to manufacture the Rodono extendable swing auger and can be bought from the manufacturer on new augers. Might be able to dump all the hoppers on your trailer without moving the truck if you park in the right spot. | |
