| The right outer three rows settles down when planter is in the raised position like when turning around on the end. It has settled almost all the way down during the time it takes to turn around. The left section stays raised. We have had the right hyd. cylinder rebuilt. No change. We have switched the right lift cylinder with the left one. The right section still settles. Have changed several solenoid valves on the main hydraulic control box with no change. The dealer does not have an answer for our problem. | |
