Search Forums | Classifieds (127) | Skins | Language
Case 4440 aim command flex problems
crazycooter
Posted 6/12/2019 12:36 (#7555029)
Subject: Case 4440 aim command flex problems
New to me one year old sprayer doesn’t stay on rate when starting into corners or small areas where only a few nozzles start spraying. It way over applies for ten feet then will underapply at half rate for roughly 100 feet. Once it is on the correct rate it will stay there going into a corner but not upon start up
It works fine in square fields but terrible on fields with corners.
Is anyone else experiencing these problems
