4720 Sprayer direction not always forward
terry1267
Posted 6/11/2019 20:07 (#7553910)
Subject: 4720 Sprayer direction not always forward
SW Ohio
2600 and a 6000 Receiver running auto trac and swath control. If you back into a corner about half the time it switches the Sprayer direction on the screen. Then as you take off it has your shut offs working opposite of what you want, as in it’s overlapping on one side and leaving a skip on the other. Takes a good ways thru the field before it turns around on its own. Also at times it shows the sprayer moving thru the field at an angle but yet in a straight line. Any thoughts?
