sc ia | I don't understand why you think you would need to adjust the draw bar lenghth. We never changed from the standard position. There are shims to adjust the width of the box that the draw bar goes in so there isn't much side to side clearance. They are easy to hook up.
Most have 2 steel rollers which I would prefer over one rubber.
I pulled ours home with a regular hitch in the receiver on the truck.
Probably around $8,000 to 12,000 depending on the condition. | |
