Posted 6/10/2019 17:25 (#7551963 - in reply to #7550884) Subject: RE: ? About CaseIH individual nozzle control
MT
What happens if you put overlap control off on pro700 and come at an angle onto a sprayed area with overlap button pressed on capstan monitor? Maybe your overlap settings are not the same on both monitors. Capstan monitor only uses GPS signal from Pro700 but has its own coverage map.
